Asgard 之ReplicatorsThe Replicators
复制者
The Asgard have been largely unable to help Earth and the Milky Way against the Goa'uld due to a war with a greater enemy, the Replicators .
asgard无法帮助地球和银河系其他星球摆脱goa'uld主要是他们有一个更大的敌人——复制者 。
The Replicators easily adapted themselves to become immune to the energy-based weapons of the Asgard, resulting in a war that was mostly just containment of the Replicators.
复制者很容易适应自己成为免疫于asgard以能源为基础的武器 ,导致战争只是提升了复制者的战斗力XXX。
Human weapons, however, used simple chemical reactions to propel inert projectiles ( ballistics ) -- a crude method that nevertheless proved difficult for the physically small and weak replicators to adapt to.
人类的武器,非常原始,使用简单的化学反应以发射弹丸( 弹道 ),事实却证明复制者的身体难以适应。
SG-1 has provided assistance to the Asgard on several occasions, as human minds are more capable of coming up with "stupid ideas" than Asgard minds are.
SG-1在多场合中的对asgard提供的援助,证明人类的原始头脑比asgard更有助于发掘解决方案——"愚蠢的想法" 。
Major Carter uses one such "stupid idea" to destroy a replicator ship by luring them into hyperspace with the newest, but incomplete, Asgard ship (the O'Neill ) which she then remotely explodes [4] , after which Thor promises on behalf of the Asgard that after the defeat of the Replicators, the Asgard will dedicate all their resources to help defeat the Goa'uld.
卡特的使用原始方法之一,这种"愚蠢的主意" ,通过最新的、但不完整、 asgard舰( 奥尼尔号 )引诱复制者到超空间遥控引爆[ 4 ]并摧毁他们一个舰堆 ,随后,THOR乐于提供更多的资源来防卫地球对付goa'uld作为回报...
With the help of SG-1, the Asgard were able to lure all of the Replicators into a time-dilation field, with the intent of trapping the Replicators for thousands of years (that to them would be mere minutes).
借助SG1的帮助 , asgard成功的吸引所有的复制到一个时间扩张领域,外面世界的几千年仅相当于膨胀区域中复制者的几分钟。
Unfortunately, escape for the Replicators was later made possible; two years later, the Replicators escaped the black hole created by the Asgard using the time-dilation device and launched an attack on the new Asgard home world, Orilla.
不幸的是,两年后复制者逃走成为可能,复制者篡改并使用asgard的时间扩装置生成黑洞逃脱,并向asgard的新家园orilla展开攻击 。
下面也整理完毕
第一次翻译,狗屁不通的,大家谅解哦
Despite an attempt to prevent this by Aegir by attacking the Replicator ship as it emerged from hyperspace, before it could raise its shields, many Replicators survived and landed on the planet, among them the human-form Replicator known as "Fifth".
asgard Aegir 试图 攻击刚脱离超空间且无法升起防护罩的复制船并阻止它入侵,可惜很多复制存活并降落在这个星球上,其中包含以人的形式被称为"第五"的复制者 。
Colonel O'Neill, with the knowledge downloaded from a Repository of the Ancients , was able to devise a weapon that permanently jammed the Replicator intercellular communications 'network', rendering all Replicators affected by this weapon unable to self-assemble and simply fall apart into their constituent components.
从古人数据库中下载了古人知识的老O上校则可以设计一个武器,永久性的分离复制细胞间的通信网络' ,使所有复制受这种武器攻击后不能从新组装,简单土崩瓦解成其组成碎片。
Thor was able to engineer a larger version and fire a planet-wide shot that would disable all replicators on Orilla, though many (including Fifth) escaped.
Thor 创建了一个较大的版本并对行星全球开火,将终结所有在orilla的复制者 ,尽管许多复制者(包括第五)逃脱。
The remaining Replicators subsequently turned their attention to the Milky Way.
其余的复制者,随后把注意力转向银河系。
They were able to become immune to the anti-Replicator weapon, and the Asgard were able to send only Thor to assist.
复制者成功免疫了反复制性武器,与此同时asgard方面仅能够派出唯一的Thor进行协助。
The Replicators were finally defeated when the Tau'ri, Free Jaffa, and Ba'al were able to use the Dakara Superweapon to break every Replicator in the Milky Way into their elemental components.
当tau'ri ,自由JAFFA,以及ba'al(球大爷)成功使用了 dakara(一个JAFFA的圣殿)的 超级武器 攻击所有在银河系的复制者,最终把他们瓦解为碎片。
There was concern that a few might lie outside the Milky Way and survive, but thus far they have not made themselves known, if they did indeed survive.
让人担心的是,一些可能不在银河系的复制者可能回存活,但到目前为止他们还没有被发现确实生存的复制者。
