探索宇宙! 每天发布一张有专业天文学家的简短解释和说明的反映我们迷人宇宙的不同影像或照片。
2008 年 01 月 14 日
The Cocoon Nebula from CFHT
CFHT望远镜下的茧状星云
Credit & Copyright: Jean-Charles Cuillandre (CFHT), Hawaiian Starlight, CFHT
影像提供及版权:Jean-Charles Cuillandre (CFHT), Hawaiian Starlight, CFHT
Explanation: What creates the colors of the Cocoon Nebula? The Cocoon Nebula, cataloged as IC 5146, is a strikingly beautiful nebula located about 4,000 light years away toward the constellation of the Swan (Cygnus). Inside the Cocoon Nebula is a newly developing open cluster of stars. Like other stellar nurseries, the Cocoon Nebula holds, at the same time, a bright red emission nebula, blue reflection nebulas, and dark absorption nebulas. Given different mixtures, these three processes create a host of colors in this image taken recently by the Canada-France-Hawaii Telescope (CFHT) in Hawaii, USA. Speculation based on recent measurements holds that the massive star towards the left of the picture opened a hole in an existing molecular cloud through which much of the glowing material flows. The same star, which formed about 100,000 years ago, now provides the energy source for much of the emitted and reflected light from this nebula.
说明:茧状星云的颜色是由什么形成的?茧状星云被编录为IC5146,是距离我们大约4,000光年远,位于天鹅座内的一个美丽而壮观的星云。茧状星云内部有一个正新形成的疏散星团。就像其它恒星孕育场一样,茧状星云同时具有明亮的红色发射星云,蓝色的反射星云以及黑暗的吸收星云的角色。星云不同的形成过程能释放出不同的混合物质,这就形成了这张影像中众多的颜色,影像是由位于美国夏威夷上的加拿大-法国-夏威夷望远镜(CFHT)近期拍摄。基于最近探测得到的数据推测,影像左侧大质量恒星在分子云中打开了一个洞,而炽热物质从中流出。诞生于10万年前的那颗恒星现今正为星云内发出的放射光和反射光提供能源。
2008 年 01 月 15 日
Double Supernova Remnants DEM L316
双超新星遗迹DEM L316
Credit & Copyright: Gemini Observatory, GMOS-South, NSF
影像提供及版权:Gemini Observatory, GMOS-South, NSF
Explanation: Are these two supernova shells related? To help find out, the 8-meter Gemini Telescope located high atop a mountain in Chile was pointed at the unusual, huge, double-lobed cloud dubbed DEM L316. The resulting image, shown above, yields tremendous detail. Inspection of the image as well as data taken by the orbiting Chandra X-Ray Observatory indicate how different the two supernova remnants are. In particular, the smaller shell appears to be the result of Type Ia supernova where a white dwarf exploded, while the larger shell appears to be the result of a Type II supernova where a massive normal star exploded. Since those two stellar types evolve on such different time scales, they likely did not form together and so are likely not physically associated. Considering also that no evidence exists that the shells are colliding, the two shells are now hypothesized to be superposed by chance. DEM L316 lies about 160,000 light years away in the neighboring Large Magellanic Cloud (LMC) galaxy, spans about 140 light-years across, and appears toward the southern constellation of the Swordfish (Dorado).
说明:这两个超新星遗迹相互间有关系吗?为了找出答案,位于智利山顶上的8米双子望远镜指向了这个奇特,巨大而又具有双瓣的DEM L316。上面显示的影像,收获了大量重要的信息。仔细检查这张影像,同时查看钱德拉X射线天文台拍摄的数据来看两个超新星遗迹有什么不同。特别是,较小的遗迹好像是Ⅰ类超新星爆发的结果(白矮星爆炸),而较大的那个遗迹好像是Ⅱ类超新星爆发的结果(一颗普通大质量恒星爆炸)。因为两颗恒星类型在不同时间段演变,所以它们应该不是同时形成,在物理空间上是没有联系。而且没有证据表明两个遗迹发生碰撞,它们只是碰巧在我们的视线方向上重叠。DEM L316位于距离我们大约16万光年远的大麦哲伦星系内,大小约140光年,位于南方星座剑鱼座内。
本帖最后由 咖啡君 于 2008-1-25 11:17 编辑 ]
