[档案馆] 神秘博士1963版第一季第五篇The Keys of Marinus附剧照
本主题由 粉蒸肉 于 2007-10-23 23:51 设置高亮
The Keys of Marinus Marinus的钥匙
Production Code: E
Season 1, Story Number 5
Written by Terry Nation 编剧:Terry Nation
Directed by John Gorrie 导演:John Gorrie
Each episode is identified with date of transmission, duration, ratings in millions, and (for 1963-1974 only) archive status.
The Sea of Death 死海(1964.4.11|23分20秒)
11 April 1964 | 23'20" | 9.9 | 16mm t/r
The Velvet Web 天绒网(1964.4.18|25分37秒)
18 April 1964 | 25'37" | 9.4 | 16mm t/r
The Screaming Jungle 丛林尖叫(1964.4.25|23分45秒)
25 April 1964 | 23'45" | 9.9 | 16mm t/r
The Snows of Terror 恐怖的雪(1964.5.02|24分54秒)
02 May 1964 | 24'54" | 10.4 | 16mm t/r
Sentence of Death 死亡判决(1964.5.09|25分03秒)
09 May 1964 | 25'03" | 7.9 | 16mm t/r
The Keys of Marinus Marinus的钥匙(1964.5.16|25分11秒)
16 May 1964 | 25'11" | 6.9 | 16mm t/r
Archive Status: All episodes exist on 16mm telerecordings. "Sentence of Death" was held by the BBC's Film & Video Tape Library when audited in 1978; negative film prints of all six episodes were recovered from BBC Enterprises circa 1978. An Arabic print of "The Sea of Death" is also held.
所有的剧集都以16mm电视胶卷保存。“死亡判决”保存在英国广播电影录象音带图书馆,1978年,被找出来。六段剧集胶片在同年被英国广播公司恢复。阿拉伯语版的“死海”也保存着。
演员表
William Hartnell (Dr. Who), William Russell (Ian Chesterton), Jacqueline Hill (Barbara Wright), Carole Ann Ford (Susan), George Colouris (Arbitan), Martin Cort (Voord / Warrior / Ice Soldier / Aydan), Peter Stenson (Voord / Second Judge), Gordon Wales (Voord), Robin Phillips (Altos), Katharine Schofield (Sabetha), Heron Carvic (Voice of Morpho), Edmund Warwick (Darrius), Francis de Wolff (Vasor), Michael Allaby (Ice Soldier / Larn), Alan James (Ice Soldier / First Judge / Guard), Anthony Verner (Ice Soldier), Henley Thomas (Tarron), Raf de la Torre (Senior Judge), Fiona Walker (Kala), Donald Pickering (Eyesen), Stephen Dartnell (Yartek), Dougie Dean (Eprin)
The TARDIS materialises on a beach of glass bordering a sea of acid on an island on the planet Marinus. There the four time travellers discover some transparent submarines, empty save in one case for a rubber suit bearing a small tear through which the acid has apparently seeped and dissolved the wearer. Stalked by the submarines' other rubber-suited occupants, the travellers eventually make their way to a large pyramid they have seen in the distance.
Inside the pyramid they encounter Arbitan (George Coulouris), the keeper of the Conscience of Marinus - a machine designed to eliminate fear and aggression from the minds of the planet's inhabitants. Arbitan explains that four of the five micro-circuit keys required to activate the Conscience have been concealed in different locations around the planet to prevent them from falling into the hands of a creature called Yartek (Stephen Dartnell) and his followers the Voords (Martin Cort, Peter Stenson, Gordon Wales) - the rubber-suited assailants - who have developed a resistance to the machine's influence and plan to turn it to their own evil purposes. The machine has now been modified to overcome the Voords' resistance and Arbitan, by placing an impenetrable force field around the TARDIS, coerces the Doctor and his companions into undertaking the retrieval of the keys. He gives them wristwatch-like travel dials which will transport them instantaneously to each of the keys' locations in turn.
In their quest, the travellers visit such exotic locations as the city of Morphoton, where they almost fall prey to the hypnotic influence of disembodied brains (voiced by Heron Carvic) and join forces with Arbitan's daughter Sabetha (Katharine Schofield) and friend Altos (Robin Phillips); a ruined citadel, home to Arbitan's friend Darrius (Edmund Warwick), which is being overrun by rampaging plant life; a snowy wasteland where the dangers include wolves, an unscrupulous hunter named Vasor (Francis de Wolff) and a group of fearsome Ice Soldiers (Alan James, Anthony Verner, Peter Stenson, Michael Allaby); and Millenius, a city where Ian is falsely accused of murder and learns from prosecutor Tarron (Henley Thomas) that the legal rule is 'guilty until proven innocent'.
Eventually, having found the four keys, and also one fake, the travellers return to the island. In their absence, the Voords have murdered Arbitan and taken control, but Ian tricks Yartek into using the fake key along with three of the real ones and, as a result, the Conscience machine is destroyed - a fact about which the Doctor is not altogether unhappy as he considers that man was not meant to be controlled by machine.
Synopsis from Doctor Who: The First Doctor Handbook by David J. Howe, Mark Stammers and Stephen James Walker, reprinted with permission; further reproduction is not permitted.
TARDIS降落在Marinus行星的一个岛上,岛周围是酸性的海水,海滩是玻璃的。在那里四个旅行者看到一些透明的潜水艇,当酸性的海水通过破损的小洞渗出橡皮衣时,橡皮衣就会被溶解,救援就无望了。一行人被潜水艇里其他人追踪,决定去远处的金字塔。
在金字塔内,他们遇到 Arbitan(Goorge Coulouris饰), 他拥有Conscience of Marinus—— 一个用来除去该行星上居民的恐惧和进攻思想的机器。Arbitan说,5把用于运作Conscience的微路钥匙中,有四把被藏在行星周围不同的地方以防止他们掉入Yartek(Stephen Dartnell饰) 和他的手下Voords的手中——一个穿橡皮衣的——摆脱了机器的影响,企图利用那台机器力量达到他们邪恶目的。利用TARDIS 周围的一个不可渗透的力量,机器被改造成能够对抗Voords,Abitan迫使医生和他的朋友不得不着手找回钥匙。 他给他们一个类似手表的刻度盘,它会让他们瞬间轮流到达钥匙的存放处。
在寻找中,他们途径了许多异于寻常的地方,例如Morphoto,在那里他们几乎被无实体大脑(Heron Carvic配音)催眠,与Arbitan的 女儿 Sabetha(Katharine Schofield饰) 和其朋友Altos(Robin Phillips饰)会师;经过了 Arbitan朋友 Darrius(Edmund Warwick)的家里——一个由狂怒植物控制的废弃城堡;还经过了危险狼群,猎人、冰人军队出没的雪地。而Millenius则是一个会被莫名指控谋杀的城市,因为那里的法律居然是,除非你能证明你的清白,否则你就是有罪的。
最后,他们找到这三把真钥匙以及一把假钥匙并回到了岛上。 在他们不在的期间, Voords 已经谋杀 Arbitan 并且控制了机器, 但是 由于Yartek 使用的是3把真钥匙和一把假钥匙,最终机器被破坏了 ――医生却并不因此难过,因为他认为人生来就不应该被机器所控制。
制作团队
Timothy Combe (Assistant Floor Manager), Mervyn Pinfield (Associate Producer), Daphne Dare (Costumes), Raymond Cusick (Designer), Norman Kay (Incidental Music), Jill Summers (Make-Up), Verity Lambert (Producer), David Conroy (Production Assistant), Penny Joy (Production Assistant), David Whitaker (Script Editor), Brian Hodgson (Special Sounds), Peter Murray (Studio Lighting), Jack Brummitt (Studio Sound), Tony Milton (Studio Sound), Delia Derbyshire (Theme Arrangement), Ron Grainer (Title Music)
Terry Nation wrote this story to replace his earlier tale, "The Red Fort" (set during the Indian mutiny), which was abandoned when the series' plans changed in the wake of its popularity. It is memorable for the quest that its various characters end up on. William Hartnell did not appear in "The Screaming Jungle" and "The Snows of Terror" as the actor was on holiday during the taping of these episodes. For more in-depth information about the contents of this story, a complete episode-by-episode detailed breakdown can be found at the Doctor Who Reference Guide.
Additional, more detailed information about the production of this story can be found at Shannon Patrick Sullivan's A Brief History of Time (Travel).
Terry Nation根据读者取向而改变原有计划,以这个故事代替他的之前写的" 红色的堡垒 "。值得纪念的是不同角色最终不同的结局。其中William Hartnell并未在 " 尖叫丛林 " 和“恐怖的雪 "中出现。因为在拍摄这些情节的时候他正好休假。
更多的关于这一个故事的内容的深入资讯,完整情节,可以参阅“DOCTOR WHO 参考指难”。
此外,更多拍摄细节可以参阅 SHANNON PATRICK SULLIVAN的“时间简史(旅行) ”
神秘博士1963版第一季第四篇Marco Polo附剧照
神秘博士1963版第一季第三篇The Edge of Destruction附剧照
神秘博士1963版第一季第二篇The Daleks附剧照
神秘博士1963版第一季第一篇An Unearthly Child附剧照
[ 本帖最后由 粉蒸肉 于 2008-5-4 10:35 编辑 ]
  • 乖贝儿 金币 +10 辛苦了粉 2007-10-26 21:40
如果湘粤一带深目削颊的美人是糖醋排骨,上海女人就是粉蒸肉
火炬木小组+神秘博士 | Torchwood + Doctor Who
辛苦辛苦!
囧是一种生活方式,囧是一种人生态度
肉肉这翻译啊,虽然辛苦了,但还是批评下。。。好不流畅啊。。
冷眼看世界、热心做自己。
北航加班侠!
回复 3# 的帖子
是不流畅,昨天被某人搅和的所以就翻成这样了
有点古老了,
粉太勤奋了~崇拜一把,翻译这活儿实在是不轻松啊……
撒花~
觉得还是新的好看
